Hi all,
First off, just want to say this community is awesome and love the forums! Also, I'm a university student so all my software copies are 2014 or whatever is the latest offered to students.
I'm making an aerofoil rib in Inventor and now I'm trying to open it in fusion so I can assemble a wing skeleton. When I try to open the .ipt file in Fusion (2013 R1), it begins to load after I press the "open" button in the file select pop-up window, but then Fusion completely crashes about two seconds after that.
Some details from the error report:
"Unhandled exception"
<ErrorDescription AllowRT="1" CrashID="{E999FF54-A776-423C-ABD5-5F69C03C113D}" CrashDate="16/02/2014" id="5"/>
<upi_error>Error loading C:\Program Files (x86)\Autodesk\Autodesk Design Review 2013\UPI\upiconfig.xml</upi_error>
<upi_error>Error loading C:\Program Files\Autodesk\DWG TrueView 2014\UPI\upiconfig.xml</upi_error>
I tried making a simpler part in Inventor Pro 2014 (a cube), but it causes the same issue. However, the sample file fusion comes with opens up just fine. I didn't have this issue with Fusion last yeay, and suggestions? Actually, it looks like it's having trouble accessing some run files, should I jsut reinstall it?
Do you have all its service packs installed?
