About 10 years ago I did a ton of soild modeling. I haven't done it in quite a while so I'm a bit out of the loop. I would like to get back into it and the new Fusion 360 provides a great low cost way to get going considering I don't qualify for any sort of discount (student etc).
I have two questions:
1. Are there any recommended guides or tutorials for Fusion 360 yet? I would prefer a book but when I search online I find nothing for Fusion 360 but quite a bit for Inventor. I looked all over amazon.com.
2. Is Fusion 360 the same thing as Inventor? Is it simply the newest version of Inventor or are they different? That would explain the lack of books for 360 if they happen to be the same thing.
Thank you much!
Thanks for asking.
The Fusion 360 installation itself is about 5GB streaming.
After that the data use depends mostly on you saving designs to the cloud. You can mitigate this a little by working "offline" for short periods of time. Your computer stays online, but Fusion stops sending large data to the cloud.
This is only typically used when internet is spotty. You will miss out on some benefits: offline mode does not save every version, only the latest. So your model history will only show the versions you save when you re-attach to the cloud.
You cannot work offline for more than 2 weeks.
Please let me know if you have any more questions.
hi,
i seen inventor and fusion both. In an inventor number of tools are more than fusion like documantion, in sketch import excel points, etc. can I prefer inventor than fusion.
