Hi at everyone...
I need to open a file that I've done on fusion 2013 with an older version (1.0.0.79)..it's a simple sketch, but if i save it as dwg on the older one it says that the file is still open or is just only read, but it's really none of the two...how can I do?
Solved by Phil.E. Go to Solution.
If you have access to AutoCAD you can 'backsave' to older versions.
However, you say it's a simple sketch. Have you considered re-drawing it?
Feel free to ask more questions, we're always glad to help. Otherwise, please mark this with Accept as Solution so that other users can benefit from it.
HP EliteBook 8560w Win 7
13" MacBook Pro, mid 2009 OS X 10.8.4
Portland, Oregon
Hi Phil, thanks for the reply...
I've try to use dwg converter and now I'm able to open the file in autocad 2012, then I try to save it again, also trying other formats, but inventor keep telling me that's the project it's done with a newer version of inventor fusion and it isn't supported...any furhter ideas? thanks!
Sorry to hear it's not working.
Aside from just redrawing the simple sketch, the only other suggestion I have is to upgrade the Inventor Fusion 2011 to Inventor Fusion 2013. You can get it here: http://labs.autodesk.com/technologies/fusion
Portland, Oregon
