The error occurred in using Inventor 2015 Professional.However, it works well when copy and past selection of dwg. File in ipt. Sketch
I just installed Inventor 2015 Pofessional Student version on Window 8.1 and the error occured with notes "FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 799bb911h" when importing .dwg file. Would anyone help to solve the issue? Thanks
Is this error from using only Autodesk Inventor Professional 2015? Or are you somehow using Autodesk Inventor Fusion as well?
I've moved this post to the Inventor board. You had posted it in Inventor Fusion which is apparently not the right place.
(the replies above are out of order)
