Program: Inventor Fusion Tecnology for MAC
I am currently working with a project that has a considerable amount of components (over 120). When I try to export the file as *.stl to print a 3D model of it I get the following error:
"Translator failed to export the asset as file: "/Users/ChristianLagares/Documents/Autodesk/Billboard Last Prototypes/Billboard STL TEST.stl""
null pointer to body given
I believe I should also mention that the app crashes when I try the same proces as a STEP format.
Is it possible for you to share the file with me? If so, please email the assembly to andrew.sears@autodesk.com. Email me if the file is to large and I will send you an FTP site to upload the file onto.
Andy
Fusion QA
