Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Error while exporting STL file
1 REPLY 1
christianlagares
997 Views, 1 Reply
Program: Inventor Fusion Tecnology for MAC
I am currently working with a project that has a considerable amount of components (over 120). When I try to export the file as *.stl to print a 3D model of it I get the following error:
"Translator failed to export the asset as file: "/Users/ChristianLagares/Documents/Autodesk/Billboard Last Prototypes/Billboard STL TEST.stl""
null pointer to body given
I believe I should also mention that the app crashes when I try the same proces as a STEP format.
Christian J. Lagares Nieves
Undergraduate Prototype and Design Engineer
NDT-Lab UPRM Research Assistant
Undergraduate Student
Department of Mechanical Engineering
University of Puerto Rico at Mayaguez
1 REPLY 1
Is it possible for you to share the file with me?  If so, please email the assembly to andrew.sears@autodesk.com.  Email me if the file is to large and I will send you an FTP site to upload the file onto.
Andy
Fusion QA
