Inventor Fusion
Inventor Fusion
Valued Contributor
sanguish
Message 1 of 9 (1,752 Views)
Editing Dimensions in Sketch Mode
1752 Views, 8 Replies
11-03-2012 11:37 PM
I've been trying to follow the basic sketching tutorial. But it seems to allow editing of dimensions, and my version of Fusion doesn't seem to allow that.
Considering another message suggested that you could do it, I'm sure this is my error.
So what am I doing wrong?
I can dimension things (although the first dimension attempt in that video between the two circle centers fails) but I can't modify dimensions.
When you escape the dimension command - what happens when you click on a dimension?
JDMather
Message 2 of 9 (1,750 Views)
Re: Editing Dimensions in Sketch Mode
11-04-2012 01:11 PM in reply to: sanguish
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Valued Contributor
sanguish
Message 3 of 9 (1,744 Views)
11-04-2012 10:15 PM in reply to: sanguish
After having tried this for literally weeks, and having it fail, it worked. So I think I wasn't doing something right.
Does parametric dimensioning also work then?
Please ship this thing! :-)
Active Member
CDT12860
Message 4 of 9 (1,721 Views)
11-07-2012 06:50 AM in reply to: sanguish
I have tried and tried to edit dimensions and NO success.  I have tried to buy a book NO success.   Looking for solutions.
Clifford
JDMather
Message 5 of 9 (1,709 Views)
11-08-2012 01:44 AM in reply to: CDT12860
CDT12860 wrote:
... I have tried to buy a book NO success.   Looking for solutions.
Clifford
Search for FREE classes here from past AU sessions by Kevin Schneider.  http://au.autodesk.com
Active Member
CDT12860
Message 6 of 9 (1,666 Views)
11-15-2012 04:31 PM in reply to: sanguish
I have search for several hours without sucess.
Clifford
Valued Contributor
sanguish
Message 7 of 9 (1,660 Views)
11-15-2012 09:23 PM in reply to: CDT12860
First, definitely do the tutorials that come up (the video ones) they're well worth it.
There is also a manual in PDF form. But i can't remember where I found it. It might be as simple as the help menu
but, if you are working on a sketch. the sketch is in edit mode, and you're in dimension mode, you can just double click on a dimension to change it. It's the being in the right modes that is likely getting you (and was me).
Plus, you also can do math in the field (+ - * / ) which is really useful
JDMather
Message 8 of 9 (1,651 Views)
11-16-2012 02:05 PM in reply to: CDT12860
Clifford
http://au.autodesk.com/?nd=classes&filter_keywords=&chunk=15&filter_material=&filter_personal=&filte...
Active Member
CDT12860
Message 9 of 9 (1,644 Views)
11-17-2012 06:20 AM in reply to: JDMather
Thank you, thank you, THANKS.
C
