Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Create a 2d cross-section from 3d proe model for 2d analysis in CFD
5 REPLIES 5
1535 Views, 5 Replies
I have a 3d proe assembly and would like to cut a cross-section from 3d model to do 2d analysis in CFD. I am new to Inventor fusion and trying since couple of days but not successful. I am not sure if this can be done or not in fusion but might have some round about ways to do this using both fusion and simulation CFD. Any ideas which could be of help will be appreciated.
5 REPLIES 5
Phil.E
What is the file type you wish to use for CFD?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
I have a 3d proe model(.asm file) and opened in fusion.  I would like to cut a crosssection of the model  and have  a 2d version.
Phil.E
Sorry about the confusion.
I am asking what file type do you wish Fusion to create from your 3D .asm file? (so it can be opened in CFD)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
 .dwg file.
Phil.E
Have you tried the following:
  1. Create a work plane where your slice should be created
  2. Project cut edges to gather your slice curves
  3. Save as DWG to open in CFD
I don't know CFD but it should be able to ignore solids and look at just the 2D profile in the sketch.
If not, you might have to delete the solid body in Fusion and leave the sketch visible. The dwg contains the sketch curves only at this point.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
