Just as in a nightmare, after finishing the project, the saved file doesn't want to open again, it makes inventro fusion crash and an error report come out (attached here)
Is there any solution besides just re doing all?
Solved by Phil.E. Go to Solution.
The file opens in Inventor and AutoCAD Mechanical. And yes, it crashes in Inventor Fusion. We're looking into the cause of it.
In the mean time, I have saved a copy out of AutoCAD that will open in Inventor Fusion. Please find it attached.
This is how it looks in Inventor and AutoCAD. Fusion will warn you about AutoCAD data being removed when you open it, but it doesn't appear to affect the model.
