Inventor Fusion
Active Member
s.borisov
Message 1 of 3 (449 Views)
Communication center channels
449 Views, 2 Replies
06-29-2012 09:55 PM
I have Autocad 2013 and Inventor Fusion 2013 on Windows 7 Home Premium. When starting the communication channe and after making the settings (country/region and check for online content) I can't see any of the autodesk channels. This happens in both of standard user and administrator profiles. Can anybody help me with this error?
Regards!
Valued Contributor
PolemEngineering
Message 2 of 3 (349 Views)
Re: Communication center channels
09-10-2012 07:12 AM in reply to: s.borisov
Has this problem been solved, because I have the same problem.
I also had problems with access to the online help. This has something to do with our ISA-server. Today my system-administrator gave me temporary full access (no limitations). This solves the problem with online help (now try to find out whit firewall-setting needs to be changed), but I still don't see any Autodesk Channels.
Autodesk Inventor Professional 2014 SP2
Employee
Macro.Liu_Autodesk
Message 3 of 3 (282 Views)
09-23-2012 11:19 PM in reply to: PolemEngineering
Have you ever tried this out in Inventor? If Inventor has the same problem, then it might because you're not able to access the Communication Center server from your network for some reason. You may contact the IT of your company or the local reseller of Autodesk on this case.
Macro Liu
Inventor Fusion QA Team
