Inventor Fusion
Member
BillFargo3197
Message 1 of 5 (300 Views)
Column forms
300 Views, 4 Replies
11-10-2012 09:55 AM
I am trying to create a set of columns that have a sweeping rope like (vine) feature going up them. I've had no luck starting with a torus and trying to modify it. I've looked at paths and sweeps. Sweeps are close except they want to just revolve when I need the tubes to be wraping up the column. Not just circling around it. Any suggestions? I can easily draw it in 2D but would rather end up with a 3D element.
Thanks in advance!
Board Manager
schneik
Message 2 of 5 (295 Views)
Re: Column forms
11-10-2012 12:03 PM in reply to: BillFargo3197
This is going to be hard to do today. What you want is a 3d sketch where you can draw on the surface of your column. the sweep along that shape.  Fusion does not have this ability. You can fake it with a lot of work.
Create a surface that represents the outside of your column. create some offset workplanes and then daw some splines in these planes. split face on the surface. you proabably need to do several. then create a sweep aplong these split face edges.
Kevin Schneider
13" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Board Manager
schneik
Message 3 of 5 (257 Views)
Re: Column forms
12-05-2012 09:06 PM in reply to: BillFargo3197
Were you able to make your forms?
Kevin Schneider
Member
BillFargo3197
Message 4 of 5 (249 Views)
Re: Column forms
12-06-2012 06:03 PM in reply to: BillFargo3197
Kevin,
Not really what I was looking for. When I get time I will put a sketch up for what I'm looking for. Though I said like a vine, it could be just a spiral tube wrapping up the column. I looked at making a series of Torus' and then trying to slice them but I couldn't figure a way to do it.  When I get time, I'll loop back on it. I can make it appear graphically correct in CAD. I was just hoping to be able to actually create it in Fusion.
Member
BillFargo3197
Message 5 of 5 (246 Views)
Re: Column forms
12-06-2012 06:21 PM in reply to: BillFargo3197
I realized that drawing a screw would pretty much solve my problem. Though I'm not sure how I would do it in Fusion, I think I can figure it out in CAD.  Another post made me think of it.
