Inventor Fusion
Inventor Fusion
Member
BradKereliuk
Message 1 of 5 (418 Views)
CNC shops having issues with my .DWG
418 Views, 4 Replies
02-06-2013 08:26 PM
Hey there folks,
So I  created a part that I want produced by a cnc mill and long story short, that every mill I send the file to they cannot open it.
I tried sending them the 2013 .dwg and that didnt work so I sent the 2010 .dwg filetype and that is not working too. I attached the .dwg so you can see if I made some sort of mistake.
Please help! =D
Employee
SallyYang
Message 2 of 5 (405 Views)
Re: CNC shops having issues with my .DWG
02-06-2013 10:43 PM in reply to: BradKereliuk
Please tell us the version of fusion and your OS info.
And what product that CNC shop used to open you DWG?
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Member
BradKereliuk
Message 3 of 5 (397 Views)
02-08-2013 01:41 AM in reply to: SallyYang
I am using windows 7 and Inventor fusion 2013, and the shop is using the programs solid edge, mastercam and gibbscam.
JDMather
Message 4 of 5 (390 Views)
02-08-2013 06:19 AM in reply to: BradKereliuk
I don't know if this has a bearing on the problem - but if I open in AutoCAD and run the List command it reports the geometry as Block Reference.
If I explode once then it lists 3D Solids which is what I suspect those programs are expecting.
Can you save in another format like STEP or IGES?
Do you have access to AutoCAD to explode the Block Reference?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Board Manager
schneik
Message 5 of 5 (377 Views)
02-10-2013 08:20 PM in reply to: BradKereliuk
Try sending them STEP files. Other DWG translators might not be up to date or have ropblems reading 3D data in the DWG.
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
