Can I stretch a raster image over a 3D model in Autodesk Inventor Fusion?
I need to do this with a 3D model that I just built.
Solved by Macro.Liu_Autodesk. Go to Solution.
Please refer to the steps below and see if the workflow is what you want:
1. In 'Sketch' panel, invoke 'Place Canvas' command
2. An 'Open' dialog will pop up, you can select an image you want, then click 'Open'
3. Select the planar face as you want
4. Adjust the image as you like and OK
Macro Liu
Inventor Fusion QA Team
I have the version you can download from the mac app store. I am new to this but i can not find how to overlay an image. I've tried everything. I can not find a canvas button. Is there another version i need to download or what?
This is what I see in Window version of Fusion
