Inventor Fusion
Member
aglaerum
Message 1 of 7 (520 Views)
Camera rolling
520 Views, 6 Replies
01-28-2013 02:24 AM
Hi
I like Inventor Fusion as it fits my needs perfectly, however I cant figure out how to use the camera tilt\pan properly.
When I hit Shift+Middle mouse button it tilts good, but when i try to pan around the object, the camera also ROLLS.
I would like the camera handling to be more like in 3dsmax, autocad or blender.
I google`d this an I cannot find a solution.
There must be a solution to this!
Please try contrained orbit setting? Does this behave more like what you wnat?
Employee
SallyYang
Message 2 of 7 (496 Views)
Re: Camera rolling
02-06-2013 11:42 PM in reply to: aglaerum
I guess the "pan" here you mean is  to orbit with a certain tilt angle.
If you are using Inventor Fusion 2013 then you can enable the compass below the view cube, just right click view cube to invoke properties dialog and check the compass option:
Please give us more information if this is not what you want, a video is prefered.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Employee
SallyYang
Message 3 of 7 (494 Views)
Re: Camera rolling
02-06-2013 11:50 PM in reply to: SallyYang
You can also using constraint orbit to do this if you are not using inventor Fusion 2013 and cannot find compass from view cube.
You need drag the handle of auxiliary circle when doing constraint orbit.
Sally
Sally Yang
Member
aglaerum
Message 4 of 7 (490 Views)
Re: Camera rolling
02-08-2013 01:52 AM in reply to: aglaerum
I want to Orbit around the object with Mousewheel + shift Without the camera rolling.
like it does in Autocad.
I am using Inventor Fusion 2013 and, I always use the compass under the Viewcube but how does that change how the camera handles?
Have you not noticed how Mousewheel + shift behaves very differently in Inventor fusion and autocad?
Board Manager
schneik
Message 5 of 7 (479 Views)
Re: Camera rolling
02-10-2013 08:21 PM in reply to: aglaerum
Kevin Schneider
15" Macbook Pro Retina - OSX 10.9 in Portland, Oregon
Member
aglaerum
Message 6 of 7 (475 Views)
Re: Camera rolling
02-11-2013 07:07 AM in reply to: schneik
It googled constrained orbit and came up with this:
On the ribbon, click
View tab  Navigate panel  Constrained Orbit
I changes the behavior of Shift + Mousewheel, to just like it is in autocad!
Thank you!
Member
aglaerum
Message 7 of 7 (473 Views)
Re: Camera rolling
02-11-2013 07:09 AM in reply to: aglaerum
While I`m on a solution roll, do you know if inventor fusion will be free forever?
If not, what will the price be?
