Inventor Fusion
Inventor Fusion
Member
0 Kudos
Post 1 of 5
Best Way to Add Material?
599 Views, 4 Replies
08-25-2012 06:58 AM
Screen Shot 2012-08-25 at 9.45.31 AM.pngWhat I am trying to do is add material to the long vertical side of this plate using the selected hole as a reference point. I want to add a radius of 7.0 mm from the center of the hole and then blend it smoothly to the plane.
Thanks!
Board Manager
63 Kudos
Post 2 of 5
Re: Best Way to Add Material?
08-27-2012 01:32 PM in reply to: Fusionewb
It's hard to tell from your picture and description what you intend with this model. Can you post another picture that better describes your intent/your problem?
In general: you can add more material with an extruded sketch profile. In the Extrude dialog set "Operation" to "Join".
Phil Eichmiller
Software QA Engineer
Fusion Quality Assurance Team
Member
0 Kudos
Post 3 of 5
09-04-2012 04:36 PM in reply to: Fusionewb
Please see the attached .pdf to see better what I am trying to do. The .pdf shows "bumps" around four of the 1/8" holes in the plate. I want to add these contours flat-sided model. These contours are simply 7.0 mm radii as measured from the center of the 1/8" holes.
I should have drawn these in the first sketch before I extruded the flat plate into a 6 mm solid but I didn't know how to draw it then, either.
Board Manager
63 Kudos
Post 4 of 5
09-04-2012 05:07 PM in reply to: Fusionewb
To add material to an existing solid:
If you sketch a new shape and wish to add material using that sketched shape, just pick the option in the Extrude dialog to "Join" and the new shape will join with the existing solid body.
To create the shape in your diagram:
The key step is to draw the arc in the sketch with the rest of the profile using either Arc commands or Circle commands. Trim the lines if needed. You can also Fillet the lines to blend them.
Phil Eichmiller
Member
0 Kudos
Post 5 of 5
09-05-2012 02:06 PM in reply to: Fusionewb
Thanks for the help! That worked out great.
....For other beginners who may be following along:
"Circle Center Radius"; placed the center point of the circle on the center of the hole
"Extrude", selected dragged down the "Join" option, and then extruded just the portion of the circle that protruded from the edge of the plate to the depth of the plate (6.0 mm).
