Autodesk has retired Inventor Fusion. We recommend our customers to visit the Fusion 360 community for related inquiries.
Inventor Fusion (Read Only)
Autodesk Inventor Fusion SP3 posted
2 REPLIES 2
schneik-adsk
1460 Views, 2 Replies
The link is here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17893575&linkID=16915702
Notes on problems fixed:
3D Annotation
        • 3D Annotation
          • Crash if the face that a 3DA resides on is removed by a modeling operation.
Interoperability with Companion Products
        • AutoCAD
          • Inventor Fusion may hang/crash when copying a large number of AutoCAD 2D geometries to 2D Sketch.
          • The result of inserting two or more Inventor Fusion DWG files into AutoCAD may be incorrect.
          • Incorrect results may occur when copying a spline in AutoCAD and pasting it into a 2D Sketch of Inventor Fusion, if the spline was originally exported from SketchBookDesigner.
Modeling
        • CER: Inventor Fusion crashes when hovering over the edge of the hole after changing the counterbore diameter to be less than the hole diameter.
Sketch
        • Inventor Fusion will crash if "Ctrl + V" is pressed while creating sketch objects, if the clipboard is empty.
Translator
        • Catia
          • Spurious surface will be created when import Catia V5 file with solid
        • Pro/E
          • Inventor Fusion may crash when opening Pro/E assembly file with multiple parts
          • Model will be 10x enlarged if importing Pro/E model to Inventor Fusion.
        • Solidworks
          • Solidworks 2011 files are now supported.
        • STEP
          • CER: Crash when opening STEP file in localized version of Inventor Fusion.
UI
      • CER: Inventor Fusion crashes when entering a value for Extrude in Ribbon, then pressing and releasing the Shift key.
      • "Show Hide" and "Isolate" in graphic context menu will not work if multiple components are selected
Kevin Schneider
2 REPLIES 2
schneik-adsk
in reply to: schneik-adsk
IMPORTANT UPDATE!
The original posting had an issue and we have reposted the service pack. Please, if you have installed the service pack please uninstall it and install the newly posted version. You can ensure you have the right service pack by checking the "About Inventor Fusion" box from the help menu. It should read version "1.3.0.31."
To remove a service pack go to add/remove programs and choose the updates view. The service pack should be listed there.
Thanks.
-Kevin Schneider
Autodesk, inc.
Kevin Schneider
Bill.Schmid
Just installed service packs 1, 2 and 3.  Rebooted.  Opened 2 Solidworks files.  Inventor 2012 SP1 failed to translate them by said they were 2011 files.  Fusion, when trying to open the files, opens a new document but it's empty.  So basically, nothing from Autodesk (AutoCAD, Inventor or Fusion) will open a SW 2011 file.
And no, I am not at liberty to post the files here.
