Inventor Fusion
Inventor Fusion
Active Member
escmojo
Message 1 of 6 (500 Views)
assembling components problem
500 Views, 5 Replies
01-21-2013 12:37 PM
First Off I am new to this and just learning how to use Inventor Fusion on a MAC.  I have been able to create some bodies and components but when I try to assemble the components it will not allow me to join them together (or specify an origin) where I need it.  I have created a cylinder and some fin components (think rocket or arrow).  When I try and attach the fins to the cylinder the only join origins I can select from are on the bottom/top face or middle of the cylinder.  Trying to understand  what I am doing wrong.   Thank you in advance!
esc
The Fusion build you are using is not supporting the accurate assembly, we will add the function in next build.
Maybe you can use some work around to solove the problem you meet now.
Employee
SallyYang
Message 2 of 6 (491 Views)
Re: assembling components problem
01-21-2013 05:44 PM in reply to: escmojo
The assembly only works on components level, so you need to create components from bodies first, then doing the assemble works.
To create component from bodies, you can find the command from the right click menu of browser nodes.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Active Member
escmojo
Message 3 of 6 (481 Views)
01-22-2013 06:32 AM in reply to: SallyYang
Thank you for the response.  I am working at the component level.  Take a look at the below example the only options when placing the joint on the cylinder is the center of the cylinder.  Based upon what I am doing it will not allow me to place the fin on the surface of the cylinder.  Let me know your thoughts.
esc
Active Member
escmojo
Message 4 of 6 (468 Views)
01-23-2013 01:09 PM in reply to: escmojo
Just to be really clear I am trying to get the edge of the fin that the red arrow is pointing too....to join flush with the side of the cylinder....where the green arrow is pointing too.  When I edited the gif it got messed up but I think it still gets the point across.  Thanks in advance.
Scott
Employee
Mike.Zhang
Message 5 of 6 (457 Views)
01-24-2013 07:02 PM in reply to: escmojo
Mike.Zhang
SQA Engineer
Active Member
escmojo
Message 6 of 6 (439 Views)
01-26-2013 11:36 AM in reply to: Mike.Zhang
Thank you.  This worked.
Question though what other producs does Autodesk have for Mac that are maybe more fully featured for doing this kind of thing?  Also that doesn't crash as much.  Would this be "autodesk inventor"?
