Inventor Forum
Weldments, fillet weld
4 REPLIES 4
280 Views, 4 Replies
Hello
I am trying to fillet weld a pipe to a weldneck flange and in order to make a correct welding there have to be app. 2 mm gab between the two parts, but when i do the welding with the gab inv. tells me that the two faces do not interact. Is there a way to make this welding?
Best regards
Mads
4 REPLIES 4
Mads,
The 2 mm gap is to wide for Inventor to assume the
parts are suppose to be touching.
For gap welds like this, I use an iPart for
the weld filler material.
John
Hello
Best regards
Mads
Currently you have to use the Cosmetic Weld, as it does not support allowances for distortion. As
Gary said a few days ago "it is work in progress".
Workaround that sometimes works: Assemble the components with faces touching, apply welds, then
adjust assembly constraint to provide you with a gap. Inventor complains, but the weld is still
there and so is the gap. Haven't tried it with a 2mm gap, but it works with a 0.060" gap and a 4mm
weld on 60x40 box section.
John Bilton
John,
Does this work with solids that have mass or just cosmatic welds?
Also, after stretching the weld can the weldment be derived into a single
part?
John
"John Bilton" wrote in message
news:DCCE7897B1E1E1E50F4C5D3C16832166@in.WebX.maYIadrTaRb...
> John Bilton
Yes, but as I say Inventor complains about it.
>part?
Don't know, give it a try and let us know how you get on (teaching 5.3 essentials today so have not
got access to R6 to try it myself)
John Bilton
