My company recently upgraded to Inventor 2022 from 2018. An issue I've run into is that, regardless of whether the box is checked or not, the ViewCube no longer plays animations when clicking on it. It just snaps to the new orientation, which can be a little disorienting. Is this a bug or am I missing something?
Solved by kacper.suchomski. Go to Solution.
There's an option you need to toogle to fix that (right-click the cube) :
Thanks for the suggestion! I've tried that and it isn't changing anything. Even when I close and reopen the program, whether I've checked the box or not (or toggled it), it still just snaps to the view.
That's very strange indeed!
Maybe Application Options -> Hardware is set to Software Graphics?
Did you install the software with UAC at a minimum level ad disable the antivirus?
Have you all updates instaled?
Hi
Can you record the behavior of the program?
Kacper Suchomski
Check Settings -> Display -> View transition time (seconds)
Kacper Suchomski
0 seconds means no transitions (jump), higher values are transition animations.
Kacper Suchomski
