Inventor Forum
Using iPart & iAssembly to create cylinder assemblies with custom stroke length
7 REPLIES 7
Message 1 of 8
1363 Views, 7 Replies
I understand the basics of iParts and iAssemblies but am not sure if this is possible...
I want to model a 2-part hydraulic cylinder assembly with dimensions driven from a table AND be able to include a custom stroke length as inputed by the user (the physical length of the rod, rather than how far a fixed length is allowed to travel).
I know I can generate an iPart family for the 2 members of Assembly and then place these inside an iAssembly. What I can't seem to do is still vary the stroke length from iAssembly level.
Has anyone got any ideas?
It would be amazing if this was possible. I've got approx 10 cylinders-types to model, each with 10+ configurations.
Tags (2)
7 REPLIES 7
Message 2 of 8
MingweiGao
Sure, you can do it by ipart and iassembly. One of my colleague made a similar hydraulics cylinder several months ago. Like the attached picture. In addition, attached file includes the inventor models for your reference. Hope this will help you.
Steven Gao
Sr. SQA Engineer
Message 3 of 8
in reply to: MingweiGao
Thanks for your response - forgot to mention I'm using 2012... I'm getting the following error:
"Database schema for file C:\xxxxx.iam (17.0(build 170095000, 95)), which is newer than this version (16.0 SP1 (Build 160190100, 190)) of the software"
I'm assuming you're on 2013? Is there anyway I could see the file in 2012 format?
thanks
Message 4 of 8
Also, I'm looking for a solution whereby the user can enter a custom stroke length (any value they want). Does your model do that or are you stuck with multiple pre-defined lengths as created in the iPart?
Message 5 of 8
MingweiGao
Yes, the models are created on AIP 2013 and it seems no method to transfer them to 2012 version. How about downloading and installing 2013 on trial.
Steven Gao
Sr. SQA Engineer
Message 6 of 8
MingweiGao
We only pre-defined multiple strokes as created in the iPart and user can select the stroke and other key parameters.
Steven Gao
Sr. SQA Engineer
Message 7 of 8
Ok I understand how to do it the way you guys have I think. I'll have a look when I get the chance to get 2013 trial.
Is there any possibility of doing it the way I'd like to with an inputable custom stroke length (any value)?
I could see this being really useful if anyone has a soloution, at the moment I'm stuck Smiley Sad
Message 8 of 8
Anyone have any other ideas?
