I need to copy about 15 user parameters from 1 part to about 300 others. I used the DA to copy the iproperties but the user parameters are also needed. Any ideas?
Thanks in advance.
You could export/import the parameters to a .xml file (from Manage Tab, Parameters Panel). Not sure how you could import them from the one file to multiple files as a batch job or across multiple ipt files.
