Inventor Forum
URGENT: Student in dire need of getting Inventor 11 functioning PROPERLY
7 REPLIES 7
Message 1 of 8
240 Views, 7 Replies
Ok, I installed the program with no errors (erased adobe flash for the install)...
Everything boots fine. I get in the program and start a new project no problem.
However... I tried following tutorials... and the first one involved making a rectangle and Dimensioning it in order to turn it into a square....
Such an easy feat... however it DOESNT work on MY computer.
I will make the rectangle... make the dimensions... go to edit the size... edit the size... hit enter... (or the checkmark) and NOTHING happens...
In a desperate attempt, I installed it on my buddies pc... WORKS FINE!
So, I did this to make sure I was not the problem. I am doing it correctly.
It works like a charm on my buddies pc... why does it not work on mine? What Gives??
Please help me out, I'm sure it's a stupid setting somewhere... just dont know where it is?
EDIT
Just wanted to clarify the post...
The dimensioning and resizing works perfectly on other computers (such as my buddies pc as well as the computers at school)
So, I am doing the process properly, just not getting the same results on my pc.
Again, the dimensions work fine, but when i edit the size... it doesnt update the size of the rectangle on the grid... it does nothing. No errors... nada...
Edited by: envisioning on Sep 17, 2009 5:27 AM Edited by: envisioning on Sep 17, 2009 5:29 AM
7 REPLIES 7
Message 2 of 8
SMB2201
I am assuming you can change a dimensions value but hitting enter doesnt change the length of the line? Does going to Tools > Rebuild All have any effect? Cant think of a setting that would delay the change in dimension value like changing the offset value of a workplane does which requires a rebuild to show new position. Could be a graphics thing or other hardware related issue. Have you checked the bottom left corner to see if there is a prompt waiting for you to select, change or enter something?
Message 3 of 8
Correct... I can change the value... but when hitting enter... the shape and the value stays the same.
It's ridiculous
also, there is no message or prompt anywhere... Edited by: envisioning on Sep 17, 2009 6:24 AM
Message 4 of 8
Did you apply Fix constraints to your sketch?
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
http://teknigroup.com
Message 5 of 8
no i did not fix the sketch...
thanks for the quick replies fellas... but i think the first response was correct.. i think its just a hardware issue
also i am running vista 64bit... i understand that the software is not supported for this OS..
Message 6 of 8
That is correct. Did you install using these tips?
http://teknigroup.com/tutorials/InstallAdsk2009.html
Message 7 of 8
JDMather
Attach the file here.
Students can download Inventor 2010 64-bit version for free from http://engineersrule.org and register to activate free 13-month license.
Message 8 of 8
ferrisb
If you zoom around or even just go ahead and extrude your sketch does the dimension then update?
I've had this hapen with 3d sketches.
