I need help!
I want to creat a flatpattern of an iregulary cut cylinder that was made in the standard .ipt world and is now converted into a sheetmetal. I want to "Unroll" the piece out so can see the shape of it as a flat piece. Picture of it is attatched.
That can't be unfolded as modeled. The part must have a constant thickness. Post your ipt file here.
How do you plan to manufacture this part?
If the ends can be square then you can remodel this using an extruded surface instead of a solid, make your cuts, and then use the Thicken feature, followed by a rip feature. This will give you a flattenable and manufacturable part.
Hi rockdesign101,
I worked up this example before I saw you posted yours. Have a look and see if you can follow the work flow to get it to flatten. (basically what mrattray said )
I hope this helps.
Curtis
Just figured it out. Thank you for your sugestions. Deleted the faces i didnt need then thicked the one face. the flat pattern will be used to trace a pattern onto a pipe
