Standard sheet number option gives you only 1, 2 and so on.
I want A1 where A does not change and 1 changes depending on sheet number.
Solved by jtylerbc. Go to Solution.
Will all sheets within the same drawing file have the same letter?
If so, you could have a custom iProperty called "SheetLetter" (or whatever name is appropriate), and just have it and your normal sheet number property close together in your title block definition. That way, once you set the letter in the iProperties, your number would count up as normal.
