Inventor Forum
Suggestion
12 REPLIES 12
Message 1 of 13
198 Views, 12 Replies
Suggestion
How about changing the Vertical and Horizontal constrain button in Sketch. Color code them to match the Origin Icon. I am forever trying to remember "was green Horziontal or Vertical?" Thanks Doug DuPont
12 REPLIES 12
Message 2 of 13
red X, that's how I remember
How
Message 3 of 13
You know, mine's on down in the corner because
it's not in the way, but I can't ever remember using it for anything. Curious as
to what do you use it for?
~Larry
How
Message 4 of 13
Can't remember where I saw it, but the mnemonic is
Red Green Blue -> RGB -> XYZ.
How
DuPont
Message 5 of 13
I use the Hor and Ver contrains for hole center marks. I put a bolt hole pattern on a sketch instead of using pattern Components. I use the contrants to line up the marks horizontally and Vertically. Doug
Message 6 of 13
I often use it for measure.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Larry Caldwell" wrote in message
news:8C28C78EDEF390D4276E36C7C05A8DAD@in.WebX.maYIadrTaRb...
> You know, mine's on down in the corner because it's not in the way, but I can't ever
remember using it for anything. Curious as to what do you use it for?
> ~Larry
Message 7 of 13
This works very nicely too.
Then when dimensioned properly you can move the
hole pattern fairly easily.
-Bill
I
Message 8 of 13
Use "Look at" and click the sketch plan you are working on. The view will align such that vertical is vertical and horizontal is horizontal. This way, you don't need to reference the origin icon.
Rick
Message 9 of 13
Kent, could you elaborate some more how you use the origin icon to measure?
Or am I misunderstanding?
Message 10 of 13
That's what I refer to it for as well. Especially when getting x, y, z
deltas.
Sean Dotson, PE
http://www.sdotson.com
...sleep is for the weak..
"Kent Keller" wrote in message
news:DE15256CAF70B4585B09626404A2D48F@in.WebX.maYIadrTaRb...
> Kent
I can't ever
> > ~Larry
Message 11 of 13
How?????? Please!!!!
Message 12 of 13
Just for reference on what the measure tool returns. Depending on what you pick of it
will give you different things, but if you pick a point it will give you x, y, and z and I
use the origin to determine what direction x , y, or z currently is
Kent
"Sean Dotson" wrote in message
news:D1BD344610DB95352BA25CE224E1EA4B@in.WebX.maYIadrTaRb...
> deltas.
Message 13 of 13
Thank you Kent, that is very useful information. Now I can measure between parts. Always wondered how to do that easily.
