This assembly was created on a 45 degree angle. It is a wheel and needs to be oriented 45 degrees counter clockwise:
Is this possible or do I need to edit the assembly.
Solved by blandb. Go to Solution.
Edit the view > Right click view cube > Custom View Orientation.
Use the tools to get the view you want.
Hi! To be more specific, Rotate at Angle is also available there. You may rotate the view precisely.
Many thanks!
