Inventor Forum
Roll Back 2020.1
10 REPLIES 10
Message 1 of 11
chrisw01a
1403 Views, 10 Replies
Roll Back 2020.1
Any way to uninstall the latest update without having to uninstall inventor and start over?
The version is a fail.
Any help will be greatly appreciated!
10 REPLIES 10
Message 2 of 11
Cadmanto
in reply to: chrisw01a
Not Inventor.  You will have to do a clean uninstall of Inventor and then reinstall.
What exactly is failing in this version?  Can you post a screen shot of the error you are seeing or describe exactly what is happening?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 11
chrisw01a
in reply to: Cadmanto
Thanks.
There is no error.  It just vanishes periodically after saving a document.
There are two events in event viewer but the temp files that it references do not exist.
Message 4 of 11
chrisw01a
happening on two workstations also...
Message 5 of 11
Mark.Lancaster
@chrisw01a
Usually this points to an out-dated graphics card driver.   Have you updated yours for 2020?  Or are you saying you never had this issue before 2020.1?
Have you gone into Windows Control Panel and removed it
Mark Lancaster
Message 6 of 11
chrisw01a
in reply to: Mark.Lancaster
We didn't have the issue before the update but I can sure try a new driver.
And do I did not think to look at control panel.
Will check it out.  Thank you!
Message 7 of 11
Cadmanto
Look at the link I gave you in my first posting about a clean uninstall.
Or, before doing the uninstall, try the Inventor reset tool.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 8 of 11
SBix26
I'm not sure why the usual method to uninstall an update wouldn't work in this case.  The below image is from Windows 7 Control Panel > Programs and Features > Installed Updates.
Sam B
Inventor Pro 2020.1 | Windows 7 SP1
LinkedIn
Message 9 of 11
chrisw01a
in reply to: SBix26
Thank you guys.  We just uninstalled the 2020.1 update for now.
Message 10 of 11
johnsonshiue
Hi Chris,
Do you mind elaborating the issues in 2020.1 causing you to uninstall it completely? Could you point me to the threads?
Many thanks!
Software Test Engineer
Message 11 of 11
chrisw01a
in reply to: johnsonshiue
Message #3 of this post.
Usually happens after saving.
