Could somebody please point me in the right direction with this no doubt very simple issue.
Just for the record I've had no tuition except youtube videos & have no previous cad experience!
Using Inventor 2016 I'm trying to make a basic door profile lets say 2000x850mm which I'd then like to be able to adjust sizes quickly to suit.
Along the height of the pan is a series of holes formed from the center point using a rectangular pattern.
My problem is when I resize the pan it only does so from 1 side, leaving all the holes offset?
The main pan is in one sketch & the holes are in another.
I've tried using so many different methods I've finally given up.
Please see the pictures to see exactly what I mean
Any help greatly appreciated.
Attach your *.ipt file here and end all doubt.
Hi, As requested the .ipt file for my offending part!
Can I just say since this drawing I've been trying so many different constraints.
Until I understand this issue I can't make anything adaptive.
Thanks for your help.
Do not use sketch patterns - use Feature Patterns for the holes.
and
your sketches are not fully defined anyhow?
You should probably install Service Packs 1 and 2 as well.
Hi Ricky2k13web,
See these links:
mi_5a_034.ipt 102 KB Inventor 2015 file
Auto spacing (holes) - SB.ipt 118 KB (from this link )
I hope this helps.
Curtis
Thanks guys for the pointers.
I'll have a good read over the weekend when not so tired.
Cheers
