Inventor Forum
Removing Hidden Lines in a Drawing View
5 REPLIES 5
7413 Views, 5 Replies
I am trying to take the visibility of some unneeded hidden lines off of an assembled view on my drawing sheet. Yet i am only taking the visibility of the hidden lines off on one of the parts in the assembly and there are A LOT of them. I know how to select the lines, right click, and turn the visibility of them off that way but there are far to many of them and it would take me quite some time to do this. This is my reasoning for wondering if there is an easier way of doing this such as just turning the visibility of the hidden lines off on one part in an assembly. If you know anything about how to do this i would greatly appreciate the advice. Thanks.
5 REPLIES 5
mcgyvr
rmb on the part in the model browser (correct view) and uncheck hidden lines.
Wow that was alot easier than expected. Ive had a problem with that a few times before and i am glad i asked for your advice. Thanks alot!
Or change your selection priority and select
graphically 🙂
rmb
lines.
in reply to: mcgyvr
I don't know what took me so long to look up this topic, but over 10 years since the initial question and it still proved helpful. Thank you!
szwackerow
To deactivate hidden lines for all parts, edit the drawing view, and under Style activate "Hidden Line Removed".
Also, if you try to remove the hidden lines using the other method from the last or the only part, it is grayed out. It forces you to remove hidden lines for the whole view.
