I've recently ran into a strange issue.
Sometimes there is a need to review older parts, with many suppressed features. Unsuppressing them would create a horrible mess, so there is a need to carefully track all the related children of the suppressed feature, to delete or redefine them.
But sometimes the "Relationships..." does not appear in the RMB menu:
How do I make it visible?
Thank you!
P.S.:
I am following the instructions provided by the Autodesk here
Solved by Yijiang.Cai. Go to Solution.
Solved by sundars. Go to Solution.
Solved by 0x3FA5. Go to Solution.
Hi @0x3FA5,
Thanks for your feedback. Currently, relationships command is not available for suppressed features. I see your POV and it makes sense and would be nice to see relationships even for suppressed features. I believe this has been the default behavior since Day 1. However, i dont see any major technical issues in enabling this command for suppressed features. One ought to be able to still view the dependencies even if the feature is suppressed. Of course, we would have to change the UI and disable editing of suppressed features but otherwise, it may not be a big issue.
I have logged a request (INVGEN-36092) and we will investigate this. Until then, i am afraid, you will have to unsuppress the feature and view relationships or perhaps write a vba script to view dependencies.
-Shiva Sundaram
Dear Shiva,
Thank you for the detailed reply.
Please see below:
Where is this fact is pointed out in the help file / official documentation? I spent quite some time trying to figure out how to show the relationships and reading through the help file.
Can you please provide a link to such script? I am an engineer, not a programmer.
Thank you!
Hi @0x3FA5
I couldn't find anything on our documentation either . I had to look the code to determine this. Now, that i think of a VBA script, it could get complicated because of feature dependencies. Besides, if the part is very complex, then triaging the output from a vba script could potentially be painful as well. So far, i have not found an easy way to do this via a script.
At this point, i would say the best bet for you is to unsuppress and view the relationships - that would give you the right answer you are looking for. I will continue to look around to see if there is a way and if i find any workaround i will let you know.
-Shiva Sundaram
This idea has been implemented within Autodesk Inventor 2023. Please review the Inventor 2023 What's New article here, for more information regarding how you may leverage the page. Special thanks to everyone who cast a vote for it.
