I just started this new job about a month ago and what ive been noticing is that we use the same parts in multiple assemblies, but we also modify these parts to use in other assemblies. This poses a problem because if the original is changed and saved on accident then it messes all the others up where its used.
My question is is there a way to save a part as a "master" that way when modified the orignal wont change?
In my opinion.. If you have standard parts that are being modified for other assemblies, than they must be their own file. They are not the same part. Why would you keep them the same?
But you could use iParts or derived parts from the master (part) file..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Are you using Vault?
Either way make them a library part ...and in a location that can't be written.
If it's in the vault that's easy. If it's not ..then put it on a network location and file protect it ...so it can't be overwritten
For example. If you design a lid that fits 20 different types of boxes but now you make other boxs that that lid wont work for so instead of starting from scratch for each box you take said lid and make a couple of changes and then it works for the new boxs. Now is there any way to make the orignal lid a master before making changes that way no one accidental save over that file and changes the lid for the 20 boxes it was used for origianlly.
I hope this makes since
it's a new revision ...
If they are different numbers, then I would just save copy as, rename it and make the changes. Save it back to where it can't be changed
Thats what we do now with the save as feature, but you know how it is soemone will forget and mess everything up
Put the files on network location with limited write permissions. If it's just one person who can move it into there ..then you shouldn't have a problem. We had a pending folder, till it was checked/verifed then it was moved into the locked folder so it couldn't be overwritten.
Bonus, depending on how often your company does backup's, it would be a simple restore.
