Solved by SBix26. Go to Solution.
Thanks so much to all who have helped with this in this thread!
What I would like to know is how I can now revolve that parabola to make a paraboloid of revolution. Any ideas?
See attached (delete after examining technique).
Guys,
Thanx for the math tutorial!
The challenge I had w/the plane parallel to a plant tangent to the side is controlling the depth and width of the parabola.
JD, your ipt file is in a version newer than I have.
Can you send it to me in 2010?
I wanna see how you did it.
Thanx!
gh,
I found your bmp in my Sheet Metal Pattern Drafting book.
Should've know it was a basic shape, and should'a resorted to fundamentals.
Thanx for the reminder!
That's not "drawing a parabola." That is creating a cone and line to intersect.
I believe the OP, and I would like to know how to graph something like y = 3x^2 +2x - 4 Or y = 3(x-3)^2 +6.
Like this? Inventor has had Equation Curve for ten years, at least... what version of Inventor are you using?
Sam B
Inventor Pro 2023.2.1 | Windows 10 Home 22H2
