Iva-Br
Regardless
Hello Iva,
if I understand you right you want to export the outlines of your part for the oxygen cutting process. The easiest way is to open the part (should be a drawing of the raw part with added machining tolerances) , highlight the surface, do a right klick and choose "export surface" in the dialogue you can choose to save as DXF. Save the DXF and forward it by mail.
I hope this helps
Matthias
I already know this resource, but he does not serve! Necessary to place ipt (OXICORTES, are great plates) in formats idw. Ipt´s has that to be to be in scale 1:1, in idw. I cannot simply export! Necessary to keep link with ipt. Amount of oxicortes generated is hundreds and I cannot simply export. These plates (oxicortes), are placed in format with headings and numbers of drawings and identification with the equipment.
if somebody will be able to help me, will be grateful! Necessary to increase the formats, in different scales
Iva-Br
Solution for the presented problem! In case that somebody needs to make something similar, here the tip goes: - to save the drawing idw for the option: - FILE - SAVE - SAVE COPy - (dwg Chooses the option) - options - to advance - Export Options to choose the options of DATE SCALING (Base View Scale - Model Space) - To conclude. It can be opened the drawing in the Mcad, estara soon to send for oxicorte. Keeping the format and I number of drawing.
Already I tested in some drawings and functioned.
ivaBr
