Using Inventor 2011 sheet metal unfold/refold features, I get this message after using the command on 3 or 4 parts. Closing Inventor then re-opening will allow use on another 3 or 4 parts. Does it on all our machines. I know I'm not out of RAM because it will happen with only one file open. Has anyone else seen this, or have a solution to prevent it?
Dell T5500
6GB RAM
Win 7 64bit
Allen
Its possible...Currently I've got one file open and am using 4.5G of RAM... Inventor still holds quite a bit of stuff in memory even after files are closed.
When it happens check Windows task manager.
Task manager show the system using 37% of physical RAM (about 2.2GB). Shows Inventor's peak working memory at about 650MB. Inventor's little memory gauge in the LR corner barely shows anything being used.
Thanks for your feedback.
Allen
64-bit Inventor 2011 doesn't have a memory gauge in the bottom corner. Are you sure you installed the 64-bit version of Inventor, and not the 32-bit version?
-cwhetten
I would open Task Manager and check for anything that might be using up resources. The other would be to do a system reboot.
i happened to notice the gauge only while the message box was on screen. As soon as I closed it the gauge went away. Definitely 64bit.
Allen
I'm trying to do a weld on two pieces and get this message.
I can confirm that the "memory meter" appears only when the message is up (I'm on 2010 64 bit).
So the big question is: what can we do now?
I'm going to try restarting Inventor and, if that doesn't work, a reboot. I'll let you know what happens.
Just a restart worked for me.
I had had a bunch of stuff open earlier in the day. But looking at the task manager, memory usage appears to have gone from 2.8G to 2.6.
As long as it's fixed ... - I'm not going to take too much time to analyze the problem.
