Inventor Forum
Multiple copies of INV open - Bad thing?
5 REPLIES 5
213 Views, 5 Replies
Is there any reason with INV 5.3 or 6 that you should not have multiple
copies of the program open. I mean not 5.3 and 6 at the same time but 2x5.3
or 2x6?
The reason I ask is if I am working on a project and someone comes and asks
to have a quick look at another it is a PITA to close all files change
projects and open the new file etc. I was thinking just start a new INV
session and open a different project.
Can this be done without causing any grief?
Ta
Brian
5 REPLIES 5
Brian
I have done this a number of times in the past and the only issue I have seen is you may
not have the project you expect active thee next time you start up.
Kent
Member of the Autodesk Discussion Forum Moderator Program
"Brian Corbin" wrote in message
news:FB76EF26894913DB6621410502EF27D8@in.WebX.maYIadrTaRb...
> or 2x6?
Cool thought it might be worth just checking here first. Ya just never quite
know with these project thingys...
Ta
Brian
"Kent Keller" wrote in message
news:3A00DB849356D07667BF98DAF79D38F3@in.WebX.maYIadrTaRb...
> Brian
seen is you may
> Kent
2x5.3
> > or 2x6?
Likewise; only a few times and no problems.... I think the last instance
closed is the one that leaves the bread crumbs, but not sure.
Brian
is you may
Kent
I found the opposite. I corrupted R6 when both R5.3 and 6 was opened. I
was unable to export idw to autocad dwg in R6. Ended up uninstalling and
reinstalling both.
Ole Germer
Helping create better involute profiles for gears
http://www.geocities.com/olegermer/index.html
"Jeff Howard" wrote in message
news:2BBB3748F77CC08FC1EFAE3EB49C3653@in.WebX.maYIadrTaRb...
> Brian
seen
> is you may
> Kent
Hi, Ole.
I think the original post stated something to the effect that it wasn't going
to be an instance of different versions. I haven't attempted to do that and
don't believe it would be a good idea, either.
Jeff
"Ole Germer" wrote in message
news:3C330B3EE356D0577D2EC5664EDE9D12@in.WebX.maYIadrTaRb...
reinstalling both.
Ole Germer
