Does anybody knows how to stop loosing edges visualization under "Shaded with Edges". As soon as I rotate my solid visualization mode turn like "Shaded" only. This never happened in 2016 but starts to occur in 2017. Or anybody knows how to configure an Nvidia Quadro K2000 for the app. I'm already running with 362.56 driver. I have used the one certified by Autodesk and Nvidia but it still do the same. Also in wireframe modes, when I zoom in or out it's visible ghost edges wich disappear and appear when zooming.:'(
I believe this is a known issue ...
have you installed hotfix 1?
also check out
This is a known issue and currently is under investigation for our development team under the Incident ID 136414
Please check the article: Inventor: Shaded with Edges are lost when zooming in and out
I hope this information helps you.
First, don't bother with the ADSK Certified drivers, this went out the window when ADSK switched from OpenGL to DirectX. Use the latest Microsoft certified drivers which are 368.39
There has been some graphics issues with IV2017 as well. There should be a service pack/hot-fix out in the next bit to address some of these issues.
I would download the drivers package, do a full un-install and re-boot of the system and then install the updated drivers package. Not sure if this will fix the issues until the Hot-fix comes out.
Hi, thanks for your reply. Inventor is up to date but do the same. I've already chage 3D setting in the Nvidia control panel to 3D App - Default global settings and restart AI. It seems to stop doing the bug but I will update if something new occurs.
