I've been trying to install Inventor 2017 on my PC. It runs on windows 10 and I have done nothing to the computer but tried to install Inventor. All products fail to install and I've tried removing all of the files with the name "Microsoft C++" and reinstalled them. Still same problem. Attached will be a photo of theerror I received. Please help ASAP I have a project due next Friday and would need all the time I can get.
Solved by mcgyvr. Go to Solution.
Did you use the "install now" method?
If so DON'T (its prone to errors)... Use browser download and download all the files then double click on part 1 and it will install from there..
Well I downloaded the file from the website, then it opened up a launcher and pressed Install, im not sure if it said "now" i cant check right now because i am in my school. None of my teachers can help me so thats why im here
I'm not a student so I'm not sure if the methods are the same but go to your account page and select "View all" right under the install now button then select .."browser download" then I think the "install now" button changes to browser download or something..
This should download a few .exe files.. with names of like 001_003.exe, 002_003.exe,etc... when all files are done then click on the 001 (part 1) and it should all auto extract from there..
Hello, I have a problem to install Inventor Profesional Student Version.
This is an old thread - you should have started a new thread and indicate what version of Inventor you are attempting to install.
Do you have these three files? (or similar)
You didn't download all members of the file set. Three parts of sfx.exe files are needed.
Walter Holzwarth
