The update download only took a minute to download but the installation seems to be taking forever. The blue gauge has been stuck there for about 20 minutes. Is this normal?
Solved by ethan_howardMMXXIV. Go to Solution.
Solved by NytCat. Go to Solution.
I hit the cancel button on the installation because this is taking too long. I now have a case number with support. The confirmation email says they will get back to me within 2 days. So I'm down until then still waiting for the installation to cancel. If anyone can help me out that would be great.
It was hung, so I ended the task using Task Manager. Restarted my laptop and installation auto-started. Then it failed. I think the problem is, it was trying to download the 32-bit version onto my 64-bit laptop. I'm not sure how to download the proper version since the web site only gave me one option. Here are some screen-captures and I attached the failure log. If anyone can help me with downloading the 64-bit version that would be great. I'll keep looking too.
Back up and running on previous version. I still want to be on the latest 2020 update before we go to 2022.
Still looking for the 64-bit edition...
Autodesk Inventor Professional 2020
64-Bit Edition
Build: 373, Release: 2020.3.4 - Date: Fri 10/30/2020
Hello Ethan. I just ran it last week and it did seem to take an unusually long time to complete. This is on a fairly quick computer with an SSD. I monitored the task, saw that it was quite active, albeit at low levels and just let it run it's course. I'm sorry, I can't be more specific, I left the cubicle after determining it was just going to take some time and it was done when I returned.
Do you not have the Autodesk Desktop App? If you do, just update through that. If you don't... why not? It'll make this task so much easier. Just my 2 cents.
Yes, that's the one. Run the update from there and it'll grab the version appropriate to what you have installed. It's a no brainer.
[edit] OR, click your avatar in the top right of your browser and click "Product Updates". If your account is setup correctly, the update will be listed.
After hours, I initiated the download via the Autodesk Desktop App, had some supper, did some painting, came back about four hours and it was installed. I opened Inventor, check my version, and voila.
Thank you @NytCat for your help! I will click the ACCEPT SOLUTION button for your response.
Sincerely,
- Ethan
