Hi, I am sure this is a basic thing but as I have always worked in metric I've never had to confront this.... until now.
I've been helping a friend design a shed in timber and he wants to use Ft and inches. I've used the relevant part and assembly templates but I have all the dimensions and physical properties as inches and square inch. How can I change this to Ft and inches which is more understandable to him.
Guy
You can change the default units in part files to feet, but I believe that you will then be showing decimal feet, not feet and inches. Dimensions may be entered in feet and inches, however, by simply typing (for example) 7 ft + 2.25 in. Drawings, of course, have more flexibility in dimension display.
Thanks for the reply. I can manage the physical properties using the 'document settings' but one area I am struggling with is the fact the lengths in the BOM are purely inches not Ft and inches. I can change a setting in the parts list to give this format which is good but I wanted to use the balloon function and detail the length of each part in Ft and ".
Cheers,
Guy
I'm afraid the Balloon can only pull BOM information. In the Parts List you can change the units format, but not in the BOM.
Most customers use a "Cut List" where the Item identifies the part and then that correlates to the Parts List.
You could also add dimensions in ft-inch format if that helps.
