I would like the marking tool to work better.
Who else would want to?
https://forums.autodesk.com/t5/inventor-ideas/marker-improvements/idi-p/12419485
https://forums.autodesk.com/t5/inventor-ideas/marking-for-multi-body-parts/idi-p/12419480
Kacper Suchomski
Both get my vote 👍
I'd also like "Mark Surface" to support 'stick fonts' - otherwise known as 'single line' fonts.
"Mark Through" allows you to use stick fonts, but if you use a profile cutting tool to cut a stick font, the middle of each letter drops out. "Mark Surface" however would be a great place to use stick fonts because it would be a single-line engrave function - literally saving over 50% of the time to create identification marks on the surface of components. Unfortunately, "Mark Surface" doesn't support stick fonts.
You can add this comment to the IS post, or create your own post. I think more decision-makers will see it there.
Kacper Suchomski
