Inventor Forum
How to read View Representation name from part with iLogic ?
2 REPLIES 2
886 Views, 2 Replies
Hi
I would like that the color of a surface in part is depend of the View name.
To do this I need to suppress a feature that get surface to appear in different color in other views.
I can see that it is possible to set the View:
If Colour = "Red" Then
ocompdef.RepresentationsManager.DesignViewRepresentations.Item("Red").Activate
But how to know name of the active view in part?
Many thanks for an input.
2 REPLIES 2
cwhetten
Hi and welcome to the forum!
Using your ocompdef object, you can get the name of the active view rep with the following line:
ocompdef.RepresentationsManager.ActiveDesignViewRepresentation.Name
Hope this helps!
Cameron Whetten
Inventor 2014
Please click "Accept as Solution" if this response answers your question.
in reply to: cwhetten
Hi
Thanks for your reply.
I have now;
ViewName = ocompdef.RepresentationsManager.ActiveDesignViewRepresentation.Name
If ViewName = "Surface Treatment" Then
    Feature.Color("Extrusion8") = "SFT_Magenta"
This works very well if I execute the code in part.
I run now into next question.
How tell Inventor to run the illogic code in part, if I change view representation  in the assembly that containing the part with the code?
The part’s view representation is controlled by the assembly view representation.
