You will need to create a coil Surface Body feature as previously described.
Create a workplane perpendicular to the beginning of the helix for your Endmill Profile.
You might need a Guide Surface as well.
I see you are on 2009 which makes it a bit more difficult to communicate -
I will try to post a solution sometime tomorrow. Bump this thread back up if someone doesn't respond.
Coil command of a closed profile does not return correct geometry - be skeptical of any "solutions" that propose this technique.
Edited by: JDMather on Oct 13, 2009 1:53 PM
