Hi folks,
I have some trouble modeling a situation for FEA inside Inventor :
The plate with the stiffeners is actualy just sitting with its weight onto the other two plates (no welds). Here is the result I'm getting so far :
On both ends this is what I get (like if it was welded) :
But what I'm trying to achieve is something like this :
Any idea on how to achieve this? I've been playing with contacts, .. for an hour but no luck so far...
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"Solved! Go to Solution.
Solved by TheCADWhisperer. Go to Solution.
Attach your file here.
Partially unconstrained and set Detect and Eliminate Rigid Body Modes (read motion).
Hi @TheCADWhisperer,
Thank you for the hints, got it to work :
Kind regards,
FINET L.
