Hello!
Is there any possibility to save Face Draft default values and options? We would like to have 45° instead of 2,5° (current default) and second option instead of first option.
We are using Inventor 2020.5.
Best regards,
Rene Repina
In the registry (for 2022, but to search for other Inventor versions you just need to change the "26.0" with lower numbers):
Computer\HKEY_CURRENT_USER\SOFTWARE\Autodesk\Inventor\RegistryVersion26.0\System\Preferences\Most Recently Used Values\Face Draft\Taper Angle
Value "MRU1" should be the angle you see there.
I am guessing you could switch the "Default" or create another string (MRU2? I don't know) for the draft option to be selected as second, but that would be a question to the devs (if it is indeed possible to do it there like I know the angle is).
CAD and PLM admin | My ideas | Inventor-Vault Expert GPT (my AI brain)
Hi @Gabriel_Watson !
Thanks for the suggestion. I tried it, but it does not work. It does not show the entered value, it gets reversed to default in Regedit and MRU* values are getting reordered for some reason when I change values.
