Where having issues at my work with exporting pdf's.
At one workstation when trying to create a PDF it gives an error saying "failed to publish DWF file"
It does create a PDF file but its completely empty.
I'v tried to repair inventor, replace the dll files in the bin folder, reinstall dwg trueview and some other settings.
Is there some setting that where overlooking?
Oh and the problem only occurs when creating a PDF from a drawing, not from a part or assembly.
Thanks in advance
Wouter Vrouwenvelder
Solved by bob_holland. Go to Solution.
Hi! Does it happen to one machine only or more than one machine? Does it fail on any drawing or specific drawings? Do you have any system application blocking certain processes to proceed?
Many thanks!
It only happens in one account, in a different account on the same machine there's no issue.
So if i'm correct it's some sort of setting in his account that is off.
It's not drawing specific. I've tried .idw and .dwg, they both fail.
As far as i know there aren't any system application blocking certain processes to proceed.
Is there a way to check this?
Also the account has the same administrative rights as others.
If it's any help i'll attach the pc and inventor specs.
Thanks in advance
Hi! I suspect this is probably user profile related. You could try right-clicking on the Inventor icon -> Run as Administrator. Does it help?
Many thanks!
I hadden't tried that yet, but unfortunately this doesn't fix the issue.
Hi! Does this machine have some sort of process like anti-virus or something like that controlling what executables are allowed to be launch?
Many thanks!
One option since this works when a different Windows user logs in is that the user might have a partially corrupt Windows User Profile.
You can usually resolved this with the Inventor Reset Utility:
Please try this and let us know.
Buen día...
Tengo el mismo mensaje de error, pero en mi caso no funciona con ningún usuario en determinadas PCs.
Osea en 3 PCs sale el mensaje "Error al exportar archivo DWF", pero en realidad estoy exportando PDF, con el plugin Translator.AddIn, método SaveCopyAs() .
Pego info de caso relacionado con todo lo que ya hice:
"Buen día..
Pertenezco a una empresa que posee varios equipos y estoy en el departamento de sistemas, brindando soporte a los ingenieros que dibujan.
Herramientas: Autodesk Inventor 2017 y VB6.
Desde VB6 exporta automáticamente un archivo IDW a PDF. En muchos equipos esto funciona ok. Pero en un par de equipos sale el siguiente mensaje de error:
"Error al publicar archivo DWF". (Adjunto imagen de error)
En los equipos donde se presenta el error, ocurre para distintos archivos idw.
En VB6 utilizo la librería Translator.AddIn.SaveCopyAs().
Para solucionar el error intenté lo siguiente:
Reparé, restablecí y reinstalé inventor en el equipo. No obtuve solución.
Utilicé PDF Ilogic, como en este caso: https://forums.autodesk.com/t5/inventor-forum/pdf-ilogic/m-p/7409690#M660985.
Revisé la configuración de Inventor comparando un equipo que presenta el error y otro equipo donde funciona ok, pero no pude detectar la diferencia que ocasiona el error.Hay muchas opciones y configuraciones para revisar y soy novato en este tema,por eso pido ayuda. Pero debido a que hay equipos donde ya funciona la programación, me imagino que la solución vendrá por este último camino.
Muchas gracias de antemano."
Agradezco cualquier ayuda.
Igualmente aclaro que utilicé la Utilidad de restablecimiento de Inventor, sin obtener la solución.
