I have just uninstalled Factory Design Suite Ultimate 2013 and then install FDSU 2014. All in network versions.
Installation worked perfectly. But when I lauch Inventor Professional 2014 it shutdown and error report message appeared. Any other softwares in FDSU ( AutoCAD,3ds max design,etc ) could be launched perfectly except Inventor Professional.
I tried to repair, reinstall this Inventor 2014 but the issue still exist.
Could someone help me?
Best Regards,
Haisin R.
Inventor Professional 2013 SP1.1
Windows 7 Pro 64-bit, SP1
HP EliteBook 8460w; 8 GB RAM; i7 - 2.0 GHz; AMD Firepro M3900 -1 GB
Solved by haisin_rusli. Go to Solution.
Oh I've just found that Autodesk has released Update 1 for Inventor 2014 :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21503391&linkID=9242019
It works! Thank you for Autodesk Team!
Best Regards,
Haisin Rusli
