good to know this. would like to know why the color does not follow the part from the beginning all the way through the assembly. just one more reason i'm not a fan of inventor.
good to know there are knowledgeable people that are available to supply help
Hi Troy,
This thread is quite old. Some of the workflows have been changed. I believe it should work the way you want. What release are you on? Could you show the exact workflow you are attempting? Or attach an example exhibiting the behavior.
Many thanks!
@johnsonshiue wrote:
Hi Troy,
Many thanks!
I believe the workflow is to have a part(s) in an assembly, then go to the the View tab and create a section view (such as Half Section View ) and then go to the part file and change the color... when you return to the assembly, the sectioned face of the part will not have changed color.... but if you change the color of the part (or another sectioned part) at the assembly level the sectioned plane retains that color.
This image illustrates the above, the green part is set to be green at the part level, the blue instance of the same part is set to be blue at the assembly level, and the section is created at the assembly level... if I change the green part to be red at the part level the sectioned face will stay gray, where as if I change the blue part to be red in the assembly the sectioned face will be red.
I hope this helps.
Curtis
Hi Curtis,
Many thanks for clarifying! I believe this is a bug. It should work the same way regardless. I will work with the project team to understand it better and see what we can do.
Thanks again!
@Curtis_Waguespack, I don't see this happening either.
In my case, I see the face color change to match the part color, regardless of how I changed it:
I'm wondering if there is something I'm doing differently from you that would solve the problem for @troy.eakin, if we could figure out what that is. A setting, or something to do with View Representations, maybe? Or maybe there's just a difference in behavior between versions (I'm still on 2018)?
Interestingly, after John's reply I just checked this again, and noticed that if I clear all color overrides at the part level, and then apply a color (which would be a color override) then return to the assembly, the sectioned face is still gray, if I return to the part file and change the color (apply a different color override) and then return to the assembly, then the sectioned face matches the part color.
But I was also able to get it in a state that I could clear overides, and then apply the color at the part level just once and the assembly would update the sectioned color ... I'm not sure how I did that, but it seemed like a save of the assembly put it back to working as my first post described.
In any case this does seem to be working unpredictably.
Also, I was using Inventor 2020.1.1
Hello John, Curtis,
I believed you are using the appearance with texture to do your workflows, right?
Here is current behavior,
If the body is assigned the appearance with image, the sectioned face would use the gray one.
If the body is assigned the appearance without image, the section face would blend the body's color.
Eg, you can remove the image from Appearance Editor dialog and edit Color in Generic panel for trying again.
-Rui
Hi! The issue has been reported as INVGEN-33940.
Many thanks!
Hi Folks,
Just some update here. There is an approach to get the desirable section. The key is to create a transparent image and then use it as the section bitmap. Please take a look at
Many thanks!
