Hello everyone,
I have a Rube Goldberg machine that I am drawing and animating in IV2011 Professional. There are quite a few pieces in it and it seems that the more components that I add, the more kinks in the softare limit my process. I am no longer able to move objects manually (i must use copnstraints to position off the bat) and if i change the grounding, flexiblity, or visibility on any component I get an error message saying that constraints are no longer viable.
It is possible for me to work through these problems as i have done in the past. I'm just wondering if anyone else has the same problem as I do.
Attach your assembly here.
My experience indicates that it is almost always a user error (OK Inventor shouldn't allow) when I see this behavior.
How many parts in the assembly?
How many assembly constraints?
Walt wrote a good essay on this a while back.
32-bit or 64-bit? How much memory?
