curve length
curve length
Message 1 of 12
curve length
Hi
The curve length for sketch3 = 279.226 . How do i dimension so that the curve length = 270mm?
Regards
Fred
Inventor 2015
Replies (11)
Message 2 of 12
CCarreiras
Hi!
You can do this:
CCarreiras
Message 3 of 12
Hi Carlos
What workflow did you use please to calculate the curve length?
Message 4 of 12
CCarreiras
...1.pngor like this
CCarreiras
Message 5 of 12
Could you please attach the file you have used to calculate?
Message 6 of 12
CCarreiras
@Anonymous wrote:
Hi Carlos
While youre placing the dimention in the arc, click rigth mouse button, and select arc Length
CCarreiras
Message 7 of 12
Thank you
Message 8 of 12
How would you calculate the curve length so the holes are 30mm apart?
There needs to be 9 holes at 30mm apart
Currently the part holes vary in distance
Message 9 of 12
CCarreiras
What's the other conditions???!!! im not a wizard, i can guess what you have in your mind!!!!!! give me details!!!
You need the arc at 15mm from the interior slot arc?
The first hole starts where?
i dont know what you want in detail!!!
CCarreiras
Message 10 of 12
CCarreiras
Ok... I Get it
If you want 9 "spaces" x 30 equal 270..... you must have.... 10 holes (not 9)!!!!
Now the question is... do you want the arc concentric at 15mm? or you have the side branches with 65mm? (you cant have both)
CCarreiras
Message 11 of 12
CCarreiras
Here you have the two versions
Conditions:
CASE1
Arcs concentric
Branch with 65
arc 140
offset 12."something"
Conditions:
CASE2
Arcs concentric
Branch with 60, "something"
arc 149, "something
offset 15
CCarreiras
Message 12 of 12
thanks Carlos.....my mistake i did change to 10 after retesting and it works...no i will use the side branches - 65mm
Thanks again
