Paul or Charles
I have generated a new file. I am trying to make it work with Spec
associated spring data.
I have a problem with the part number, when inserted into an assembly the
BOM displays the drawing file, not the number of the selected spring.
Could you help me with this?
Thaddeus
"cbliss" wrote in message news:40716ea8$1_3@newsprd01...
> Paul, May I post this on my web site?
> pevans wrote:
> >Here is an i-part that I created for Century springs. You select the OD
and then plug in the values from the Century catalog. Use the pre-load
length instead of free length to show the spring as it will actually be
used. I only used the OD's that had the most selections in the Century
catalog.
> >Paul Evans
> >Project Engineer
> >Cox Automation Systems
